I was trying to connect Binance Websocket, but Error happened. and I can’t find out what is the problem of it…
Can you help me please?
CODE
from binance import ThreadedWebsocketManager
import pandas as pd
def stream_data(msg):
‘’‘define how to process incoming WebSocket messages’‘’
print(msg)
twm = ThreadedWebsocketManager()
twm.start()
Exception in thread Thread-1:
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\threading.py”, line 950, in _bootstrap_inner
self.run()
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\threaded_stream.py”, line 56, in run
self._loop.run_until_complete(self.socket_listener())
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\asyncio\base_events.py”, line 642, in run_until_complete
return future.result()
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\threaded_stream.py”, line 35, in socket_listener
self._client = await AsyncClient.create(loop=self._loop, **self._client_params)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\client.py”, line 7125, in create
await self.ping()
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\client.py”, line 7246, in ping
return await self._get(‘ping’, version=self.PRIVATE_API_VERSION)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\client.py”, line 7211, in _get
return await self._request_api(‘get’, path, signed, version, **kwargs)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\client.py”, line 7174, in _request_api
return await self._request(method, uri, signed, **kwargs)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\binance\client.py”, line 7155, in _request
async with getattr(self.session, method)(uri, **kwargs) as response:
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\client.py”, line 1187, in aenter
self._resp = await self._coro
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\client.py”, line 574, in _request
conn = await self._connector.connect(
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\connector.py”, line 544, in connect
proto = await self._create_connection(req, traces, timeout)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\connector.py”, line 911, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\connector.py”, line 1173, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\connector.py”, line 884, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File “C:\Users\akak1\PycharmProjects\pythonProject9\venv\lib\site-packages\aiohttp\resolver.py”, line 33, in resolve
infos = await self.loop.getaddrinfo(
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\asyncio\base_events.py”, line 856, in getaddrinfo
return await self.run_in_executor(
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\asyncio\base_events.py”, line 809, in run_in_executor
executor = concurrent.futures.ThreadPoolExecutor(
File "C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\concurrent\futures_init.py", line 49, in getattr
from .thread import ThreadPoolExecutor as te
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\concurrent\futures\thread.py”, line 37, in
threading._register_atexit(_python_exit)
File “C:\Users\akak1\AppData\Local\Programs\Python\Python39\lib\threading.py”, line 1370, in _register_atexit
raise RuntimeError(“can’t register atexit after shutdown”)
RuntimeError: can’t register atexit after shutdown
Process finished with exit code 0
