I’m struggling to use the local withdraw with travel rule.
Has anyone got a working example of it. I’m from the EU
What error are you encountering? Are you filling the questionnaire with all the fields provided on the website?
Im using this:
I only used the fields I had to, or do I have to provide all of them?
travelRule = json.dumps({
“isAddressOwner”: 1,
“sendTo”: 1,
“declaration”: True
What happens when you add vasp
field? If it’s Binance, the field should be set to BINANCE
Otherwise, could you share the error that you are receiving?
Hi Riley
Did you ever get this to work? Cause I’m having the same issues.
The closest I seem to get is hardcoding the JSON string using
“{"isAddressOwner":1,"sendTo":2,"vasp":"other","vaspName":"Mexc","declaration":True,}”
This gives me a 200 b’{“accepted”:false,“info”:“Questionnaire format not valid.”}’
Using Python, from the EU as well…
