Hello. I have a error typin pip install python-binance on console. Can someone help me?
Is an error regarding twisted…
Heard there’s an incompatible issue between python 3.9 and python-binance. Are you python 3.9?
Yes I have Python 3.9. So I have to install 3.8?
Suggest you give it a try
I had to install 3.7, I couldn’t get 3.8 most likely I couldn’t install Twisted in 3.8.
Does 3.7 work?
Yeah. I have the python binance wrapper working fine after installing 3.7, though I did have to download Twisted and install it manually.
The only problem I’m having is figuring out how to direct it to the testnet, but it should be fixable.
Hello. Finally I could do successfully pip install python.binance because I eliminate python 3.9 and I install python 3.8
But now in Pycharm it doesn’t recognise the API I think
Maybe I have to install Python 3.7?
Please go to a python forum to figure out how to use pycharm. If you’re already good with python <3.9 with python-binance, we’re good here. This is a binance-api related forum; Thank you for your understanding~
