Properties of aggTrade object
according binance swagger documentation
https://binance.github.io/binance-api-swagger/spot_api.yaml
there is an object AggTrade. This object has pproperties, which are only letters. Concretelly there are this letters: a, p, q, f, l, T, m and M. Specially last two are problem for me. I would like to use openapi-generator-maven-plugin, to generate java classes directly from yaml. Problem is in generated method names. In java are getters and setters generated with name getM()/setM for both properties (m,M). Is it possible to correct the api to not use only letters, but whole names for property names?
Those are the returned fields from the /api/v3/aggTrades endpoint and we can’t change it.
Hi @aisling2 ,
obviously it is an issue in the API, can we somehow create ticket for Binance developers to correct it?
Or is there any other way how to fix this?
Thnaks
Peter
