Hello. I have received authorization to use CONVERT end point. When I want to test it on testnet, instead quote response I get HTML text saying “Something bad happened”. I assume that CONVERT endpoint is not working on testnet. Can you confirm?
Yes you’re correct, the Convert
endpoints are not available via Testnet at this time.
