Problem catching binance-connector `WebSocketTimeoutException`
from binance.websocket.spot.websocket_stream import SpotWebsocketStreamClient
from websocket._exceptions import WebSocketTimeoutException
import threading
import traceback
mutex = threading.Lock()
class Bot:
    def __init__(self):
        self.ws = SpotWebsocketStreamClient(
            'wss://testnet.binance.vision/ws',
            on_message=self.message_handler
        self.websocket_reconnect = True
        self.count = 0
    def message_handler(self, _, payload):
        with mutex:
                self.count += 1
                print(self.count)
                if self.count > 10:
                    self.count = 0
                    raise WebSocketTimeoutException
            except WebSocketTimeoutException as e:
                print(traceback.format_exc(chain=False))
                raise
    def load_websocket(self):
        self.ws.book_ticker('BTCUSDT')
    def run(self):
        while True:
                if self.websocket_reconnect:
                    self.load_websocket()
                    self.websocket_reconnect = False
                print('Enter')
                print(traceback.format_exc_info(chain=False))
                self.ws.stop()
                print('---------- RESTARTING WEBSOCKET ----------')
if __name__ == '__main__':
    Bot().run()
The explanation for this code is, i want to raise a WebSocketTimeoutException exception when self.count > 10 while i am catching it in the run method, the thing is that it doesn’t get caught there, and i trying to deal with the websocket._exceptions.WebSocketTimeoutException: Connection timed out that is raised when binance closes the connection. What am i missing?
what exactly error did you receive?
The error is captured in the except WebSocketTimeoutException as e: inside message_handler, but as you can see i also raise it, it should be caught in the except WebSocketTimeoutException as e: inside run method, this is what i get:
  File "/home/user123/Proyectos/binance_tradebot/test_error.py", line 26, in message_handler
Error from callback <bound method Bot.message_handler of <__main__.Bot object at 0x7fe408869fa0>>:
