Prices not changing on spot test network
I am using “https://testnet.binance.vision/api/v3/ticker/price?symbol=BNBBTC” to get market price of BNBBTC pair but the price seems to be constant even after an hour has been passed.
Do I do use the right command or there is something else I should try?
If you get a response with the price, you should probably be fine. It is a test environment and trading frequency will not be as high as compared to the actual environment. Therefore, prices may not fluctuate as much.
Yes I get a price. I thought that this is a test environment and the prices are not changing frequently, but after 24 hours I get the same price. If it is so slow it will take weeks or even months before I manage to test my bot!
