What is the expected precision for quoteOrderQty? It is not documented anywhere. CCXT seems to use either quoteAssetPrecision or baseAssetPrecision, but these are almost always 8, and 2 in rare cases. The web interface sets it to some random number, though. For example, for BNB/BUSD I can input 0,000001 (6), and for BNB/USDT 0,0000001 (7). /exchangeInfo doesn’t return such numbers.
For the API, can I just use 8, or is it going to throw me random filter errors?
For quoteOrderQty, it follows the precision in quoteAssetPrecision. So for BNBBUSD, actually you can go as far as this 10.00000001 (it should be greater than 10 BUSD to meet MIN_NOTIONAL as well)
All the parameters can be found from /api/v3/exchangeInfo
tradingPairs = ['BTCUSDT','ETHUSDT','BNBUSDT']
#Loop though cryptos
for i in range(0,len(tradingPairs)):
info = client.futures_exchange_info()
if info['symbols'][0]['pair'] == tradingPairs[i]:
print("Price Pre ",info['symbols'][0]['pricePrecision'])
pricePrecision = info['symbols'][0]['pricePrecision']
quantityS = 5.2
quantityB = "{:0.0{}f}".format(quantityS, pricePrecision)
