Position is not closed due to a residual quantity that stays in the position
I have a crypto bot that uses a LIMIT order total quantity to close a position. That limit order will always get the [‘positionAmt’] from the /fapi/v3/positionRisk endpoint.
Although my crypto bot places a limit order with the exact total quantity placed on that position array attribute, somehow, and sometime, the position is not closed and leaves a 0.01 quantity open.
I am recording every 15 minutes the position amount, and I already confirmed that my profit order have exactly the same quantity as the value I am receiving on the positionRisk endpoint. As example:
On a ALGO/USDT position the profit order had “executedQty” = 11919.5, as the same as the positionRisk endpoint for this position trading pair, but the REAL quantity was 11919.51 . So, the position was kept open with a 0.01 quantity (and then impossible to close it with a market order because the min notional was 5).
Anyone got this issue, or any thoughts about what am I doing wrong? Thank you!
You’re encountering a precision mismatch issue when closing positions using a LIMIT order on Binance Futures. Even though your bot retrieves positionAmt (e.g. 11919.5) from /fapi/v3/positionRisk, the actual internal position may be slightly different (e.g. 11919.51). This discrepancy arises due to: Floating-point precision errors, rounding differences in how Binance internally tracks position vs. what it displays via API. Partial fills or fee rounding when opening/closing positions. Binance API returning positionAmt rounded to the symbol’s quantityPrecision (e.g., 1 decimal place), while internally storing more digits. This results in an order being placed for 11919.5 when your real position is 11919.51, thus leaving 0.01 open. I have the solition for you. Is very simle.
