I would like to know the Python code to fetch data from the Binance API and calculate RSI 7, RSI 21, stochrsi K, and stochrsi D values. I have already obtained the Binance API key.
Here is the code I have written:
The problem is that the values calculated by running this code differ significantly from the values shown on the Binance app. I would appreciate the help of experts
[my code]
import ccxt
import pandas as pd
def fetch_binance_data(symbol, timeframe, limit=1000):
binance = ccxt.binance()
ohlcv = binance.fetch_ohlcv(symbol=symbol, timeframe=timeframe, limit=limit)
df = pd.DataFrame(ohlcv, columns=[‘timestamp’, ‘open’, ‘high’, ‘low’, ‘close’, ‘volume’])
df[‘timestamp’] = pd.to_datetime(df[‘timestamp’], unit=‘ms’)
return df
def rsi_calc(ohlc: pd.DataFrame, period: int):
delta = ohlc[‘close’].diff()
gain = delta.where(delta > 0, 0)
loss = -delta.where(delta < 0, 0)
avg_gain = gain.ewm(span=period, adjust=False).mean()
avg_loss = loss.ewm(span=period, adjust=False).mean()
rs = avg_gain / avg_loss
rsi = 100 - (100 / (1 + rs))
return rsi
def stoch_rsi_calc(rsi: pd.Series, stoch_period=14, k_period=3, d_period=3):
min_rsi = rsi.rolling(window=stoch_period).min()
max_rsi = rsi.rolling(window=stoch_period).max()
stoch_rsi = (rsi - min_rsi) / (max_rsi - min_rsi) * 100
K = stoch_rsi.rolling(window=k_period).mean()
D = K.rolling(window=d_period).mean()
return K, D
def rsi_and_stoch_rsi(symbol, timeframe):
df = fetch_binance_data(symbol, timeframe)
rsi_7 = rsi_calc(df, 7)
rsi_21 = rsi_calc(df, 21)
rsi_7_value = rsi_7.iloc[-1]
rsi_21_value = rsi_21.iloc[-1]
stoch_rsi_k, stoch_rsi_d = stoch_rsi_calc(rsi_7, 14, 3, 3)
stoch_rsi_k_value = stoch_rsi_k.iloc[-1]
stoch_rsi_d_value = stoch_rsi_d.iloc[-1]
return rsi_7_value, rsi_21_value, stoch_rsi_k_value, stoch_rsi_d_value
Parameters
symbol = ‘ALGO/USDT’
timeframe = ‘1h’
Get RSI and Stoch RSI values
rsi_7_value, rsi_21_value, stoch_rsi_k_value, stoch_rsi_d_value = rsi_and_stoch_rsi(symbol, timeframe)
Print results
print(f"RSI 7: {rsi_7_value:.4f}“)
print(f"RSI 21: {rsi_21_value:.4f}”)
print(f"Stochastic RSI K: {stoch_rsi_k_value:.4f}“)
print(f"Stochastic RSI D: {stoch_rsi_d_value:.4f}”)
