Ping/Pong Rust Websocket Binance Futures
How can I add ping pong to this code so that the stream is not interrupted?
use websocket::client::ClientBuilder;
use websocket::OwnedMessage;
use std::time::Instant;
use std::str::FromStr;
use futures::prelude::*;
use influxdb2::models::DataPoint;
use influxdb2::Client;
#[tokio::main]
async fn main() -> Result<(), Box<dyn std::error::Error>> {
    let mut client = ClientBuilder::new("wss://fstream.binance.com/stream")
        .unwrap()
        .connect(None)
        .expect("Failed to connect");
    let host = "http://localhost:8086";
    let org = "wannafly";
    let token = "QPjlMBmeh-fANqZpkC_sScPbW8weLxsw9yl8Q8s7PsUiATo43_plZSathKcRHJ6NOBx9UB3Uh05RixzG4ZT7yA==";
    let bucket = "Ticks";
    let clientdb = Client::new(host, org, token);
    let mut prev_time = Instant::now();
    let done = false;
    client
        .send_message(&OwnedMessage::Text(
            r#"{"method": "SUBSCRIBE", "params": ["!ticker@arr"], "id": 1}"#.to_string(),
        .expect("Failed to send message");
    println!("новый цикл: {:?}", prev_time);
    for message in client.incoming_messages() {
        println!("message: {:?}", message);
        println!("внутри цикла");
        let message = match message {
            Ok(message) => message,
            Err(err) => {
                println!("Failed to receive message: {:?}", err);
                continue;
        match message {
            OwnedMessage::Text(text) => {
                let tick: serde_json::Value =
                    serde_json::from_str(&text).expect("Failed to parse JSON");
                if let Some(data) = tick.get("data") {
                    if let Some(tickers) = data.as_array() {
                        println!("------------------------");
                        let mut n = 0;
                        for ticker in tickers {
                            n = n + 1;
                            let mut symbol: String;
                            let mut price: String;
                            if let Some(s) = ticker.get("s") {
                                symbol = s.to_string();
                                symbol = symbol.replace("\"", "");
                            } else {
                                symbol = "none".to_string();
                            if let Some(p) = ticker.get("c") {
                                price = p.to_string();
                                price = price.replace("\"", "");
                                match f64::from_str(&price) {
                                    Ok(price) => {
                                        println!("symbol: {}:{:?}", symbol, price);
                                        let points = vec![
                                            DataPoint::builder("Binance")
                                                .tag("Symbol", symbol)
                                                .field("Price", price)
                                                .build()?,
                                        clientdb.write(&bucket, stream::iter(points)).await?;
                                        if done {
                                            break;
                                    Err(err) => {
                                        println!("Price error: {:?}", err);
                            } else {
                                continue;
                        let current_time = Instant::now();
                        let time_diff = current_time.duration_since(prev_time);
                        prev_time = current_time;
                        println!("count: {}", n);
                        println!("Time interval: {:?}", time_diff);
            OwnedMessage::Close(_) => {
                println!("Connection closed");
                break;
            _ => {}
    println!("конец цикла");
    Ok(())
For the websocket package you’re using , try to search in documentation on how the ping/pong frames works there.
The problem is:
[svelle@lenovo trade]$ cargo run
Compiling trade v0.1.0 (/home/svelle/Рабочий стол/Rust/trade)
error[E0499]: cannot borrow client as mutable more than once at a time
→ src/main.rs:50:17
36 | for message in client.incoming_messages() {
| first mutable borrow occurs here
| first borrow later used here
50 | client.send_message(&OwnedMessage::Pong(ping))
| ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ second mutable borrow occurs here
For more information about this error, try rustc --explain E0499.
error: could not compile trade (bin “trade”) due to previous error
match message {
            OwnedMessage::Ping(ping) => {
                println!("Got ping: {:?}", ping);
                     .expect("Failed to pong");
