Davibr
1
In the example below in BINANCE SPOT it works:
<?php
$sock=stream_socket_client("tls://stream.binance.com:9443",$error,$errnum,30,STREAM_CLIENT_CONNECT,stream_context_create(null));
if (!$sock) {
echo "[$errnum] $error" . PHP_EOL;
} else {
echo 'Conected!';
But in the example below in BINANCE FUTURES it doesn’t work:
<?php
$sock=stream_socket_client("tls://fstream.binance.com",$error,$errnum,30,STREAM_CLIE>NT_CONNECT,stream_context_create(null));
if (!$sock) {
} else {
echo 'Conected!';
Why?
Thanks in advance.
ishuen
2
Hi. Please provide the final url for the futures part. From here, it’s hard to know the value of those variables and what are done by the methods.
Davibr
3
It works (SPOT)
<?php
if (!$sock) {
} else {
echo "Connected - Do NOT get rekt!" . PHP_EOL;
fwrite($sock, "GET /stream?streams=btcusdt@kline_1m HTTP/1.1\r\nHost: >stream.binance.com:9443\r\nAccept: */*\r\nConnection: Upgrade\r\nUpgrade: >websocket\r\nSec-WebSocket-Version: 13\r\nSec-WebSocket-Key: ".rand(0,999)."\r\n\r\n");
while (!feof($sock)) {
var_dump(explode(",",fgets($sock, 512)));
This below doesn’t work(FUTURES)
$sock=stream_socket_client(“tls://fstream.binance.com”,$error,$errnum,30,STREAM_CLIENT_CONNECT,stream_context_create(null));
if (!$sock) {
echo “[$errnum] $error” . PHP_EOL;
} else {
echo “Connected - Do NOT get rekt!” . PHP_EOL;
fwrite($sock, “GET /stream?streams=btcusdt@kline_1m HTTP/1.1\r\nHost: fstream.binance.com\r\nAccept: /\r\nConnection: Upgrade\r\nUpgrade: websocket\r\nSec-WebSocket-Version: 13\r\nSec-WebSocket-Key: “.rand(0,999).”\r\n\r\n”);
