Last night I received this error “-1015 Too many new orders; current limit is 50 orders per 10 SECOND.”
I can see this limit in the exchangeInfo and just wanted to confirm my understanding.
Does this limit apply per symbol or is it applied on all orders for an exchange ?
Is this applied per api key ? ie. If I have more api keys, would each key be allowed 50 orders /10 second?
If I insert an order, then delete the order and insert the order again within 10 seconds, does this count as 1 or 2 orders ?
Thanks in advance
It is applied on all SPOT orders
The limit is applied to the account. Therefore API keys from the same account share this limit.
The example provided is considered as 1 order for the 10 second order limit, but 2 orders for the 1 day order limit.
Many thanks for clearing that up
One other thing - after receiving this error, i’ve addressed the issue.
Would it be ok to begin trading again or should I wait some time to prevent my account being banned ?
While banned, you will receive HTTP status codes 418 or 429 along with the header Retry-After
which indicates the duration of the ban.
While not banned, use the response header X-MBX-USED-WEIGHT-(intervalNum)(intervalLetter)
to stay within the limits of the api.
