orderID form allOrders and orderID from myTrades
Continuing the discussion from fromId error in myTrades:
Hello dino.
I read a topic where you have answer.
What is my goal - I want to have full info what was happend with my XML.
Would you like to explain me how to fix this problematic situation. When I fetch data from allOrders i got XLM with orderID=12867665 - it is first order on this asset.
symbol     orderId  orderListId                         clientOrderId     price      origQty  executedQty  cummulativeQuoteQty  status timeInForce    type  side  stopPrice  icebergQty           time     updateTime  isWorking  origQuoteOrderQty asset
153       XLMBNB    12867665           -1  and_0f93157b1e5743728a35981efebc35fd  0.028200    46.100000    46.100000             1.298637  FILLED         GTC   LIMIT   BUY        0.0         0.0  1542275559627  1542275559627       True           0.000000   XLM
When i want to find more details i query myTrades. That is answer from a query with only symbol.
       symbol         id     orderId  orderListId         price          qty     quoteQty    commission commissionAsset           time  isBuyer  isMaker  isBestMatch asset
0      XLMBNB    1252140    12867665           -1      0.028170    46.100000   1.29863700  9.722100e-04             BNB  1542275559627     True    False         True   XLM
1      XLMBNB    1253774    12868297           -1      0.029600    46.100000   1.36456000  1.023420e-03             BNB  1542325206629    False     True         True   XLM
2      XLMBNB    1265156    13051006           -1      0.032190   129.400000   4.16538600  3.117680e-03             BNB  1542702116239     True     True         True   XLM
Everything is working fine, because i have less than 500 orders and less than 500 trades.
When i (suppose) will do the same in the future - for example after 5 years.
How should i ask api about my trades XML with tradeID=12867665?
It is a little bit complicated because in future i can have for example 100000 orders and 500000 trades for this orders.
I checked on https://binance-docs.github.io/apidocs/spot/en/#current-open-orders-user_data
and
GET /api/v3/allOrders (HMAC SHA256)
has orderId as input not mandatory parametr
I checked also on https://binance-docs.github.io/apidocs/spot/en/#account-trade-list-user_data
and
GET /api/v3/myTrades (HMAC SHA256)
has fromId parametr wiht description TradeId to fetch from. Default gets most recent trades
Because both api have ID but one have fromId second fromId and both with the same description
fromId LONG NO TradeId to fetch from. Default gets most recent trades.
It was clear for my that when I have orderId from allOrders i should use it as input parametr in myTrades.
According to description i expected minimum that myTrades return trades with orderID=12867665 or all trades which was executed after my trade.
But when i quered myTrades with symbol and fromId I got empty list.
Have you solution how to fix it? How deep should i query? Should i query about all trades from ??? and next inside a loops looking for my trades with orderID=12867665 . (for me that is the worst solution).
I am open for discusion.
Is that true condition at startTime from myTrades is the same as a updateTime from response from allOrders?
Hello, the fromId is for trade id ( your 1252140) and not order id (12867665 ).
