Hi every one
I have problem with order book data ! I get data from web socket and process it with this steps :
get the ask and bids data from https://api.binance.com/api/v3/depth?symbol&limit=1000
save these data in a local variable (variable name is ‘OrderBooks’)
then get data from web socket and check lastUpdateID with this code
//— get last update id
var lastUpdateId = OrderBooks.lastUpdateId;//— drop any updates older than the snapshot
if (data.u <= lastUpdateId) {console.log('discard data'); return;
if (data.U <= (lastUpdateId + 1) && data.u >= (lastUpdateId + 1)) {
OrderBooks.lastUpdateId = data.u;
else if (data.U == (lastUpdateId + 1)) {
process new update data in three conditions :
4.1. Update data if price level exist and have new quantity 4.2. Remove where price level have zero quantity 4.3. Insert in orderBooks List if new price level
show first ten data of list
with these steps i have this problem :
thank you for your help
