Opening trade with Future API key not working on Testnet ?
Hi all,
I’ve registered and got my testnet API key okay… I can use it to retreive my trades, but not to create a new trade… How can I change it’s permissions ?
Thanks in advance,
Nick
Testnet API Keys have full permissions.
Could you provide the full url used (omitting any sensitive information) and the error received?
Thanks for you answer :slight_smile:
That’s in the error message, is that you’re talking about
https://testnet.binance.vision/api/v3/order?type=MARKET&symbol=BTCUSDT&side=SELL&quantity=1&timestamp=1639664082385&signature=2***f
The error message is in the body of the response.
The endpoint could fail for numerous reasons, however from a first glance, it may be a balance issue.
Please provide the full error response so that we can better diagnose the issue.
I got it…
I was simply using a lib that DOES NOT allow futures Order, it was trying to place a “futures” order using the spot API which therefore was not working…
But thanks a lot for your time :wink:
