Open position in futures expressed in USDT and not in asset amount
Since I have been working with the Python connector for Binance, the opening of positions in futures must be expressed in the amount of asset and cannot be expressed in USDT.
I wanted to know if there had been any update that allowed it.
Thank you
this is not a connector’s failure to support USDT quantity option. It’s this option not being available through the API (Binance API Documentation) at the moment. In the eventual case it becomes available, there will be an update in the API doc’s change log page, mentioning about it.
Thank you very much for the reply. I understand and I was just seeing that at endpoints were not possible. Do you know why they don’t implement it?
@Ramiro_Deploy I don’t have that info, sorry.
