This code establishes a WebSocket connection to the Binance streaming API and listens for messages. The code uses the websocket
library and the json
module.
The code defines several functions:
on_message_fiat
: This function is called when a message is received through the WebSocket connection. It parses the JSON message, extracts relevant information, and performs certain actions based on the content of the message. -
on_open
: This function is called when the WebSocket connection is established. It sends a subscribe request to the Binance API for a list of symbol pairs. -
on_close
: This function is called when the WebSocket connection is closed. It cancels the subscription for the specified symbol pairs.
The main part of the code initializes a dictionary l_ST_symbol_pair
containing symbol pairs and their corresponding status and parameters. It then constructs a WebSocket URL using the symbol pairs with a specific format and creates a WebSocket connection using the WebSocketApp
class from the websocket
library. Finally, it runs the WebSocket connection indefinitely, continuously receiving and handling messages from the Binance API.
import websocket
import json
def on_message_fiat(wss, message, l_ST_symbol_pair):
pars = json.loads(message)
name_pair = pars['stream'].split("@d")[0].upper()
if l_ST_symbol_pair[name_pair][1] == 'start':
for key, value in l_ST_symbol_pair.items():
if value[1] != 'start':
if value[3].get(name_pair) is not None:
value[3][name_pair] = True
filtered_keys = [key for key, value in l_ST_symbol_pair.items() if all(v == True for v in value[3].values()) and value[1] != 'start']
if len(filtered_keys) > 0:
on_open(wss, filtered_keys)
if l_ST_symbol_pair[name_pair][1] == '2_SA':
l_ST_symbol_pair[name_pair] = (False,l_ST_symbol_pair[name_pair][1], l_ST_symbol_pair[name_pair][2], {key: False for key, val in l_ST_symbol_pair[name_pair][3].items()})
on_close(wss, [name_pair])
def on_open(ws, spisok):
params = {"method": "SUBSCRIBE", "params": [item.lower() + '@depth10@1000ms' for item in spisok], "id": 1}
ws.send(json.dumps(params))
def on_close(ws, spisok):
print('cancel_task'+' '+spisok[0])
params = {"method": "UNSUBSCRIBE", "params": [item.lower() + '@depth10@1000ms' for item in spisok], "id": 1}
if __name__ == "__main__":
l_ST_symbol_pair = {'ETHBTC':(False, '2_SA', None, {'BTCAUD': False, 'ETHAUD': False}),
'BNBBTC':(False, '2_SA', None, {'BTCAUD': False, 'BNBAUD': False}),
'BNBETH':(False, '2_SA', None, {'ETHAUD': False, 'BNBAUD': False}),
'BTCUSDT':(False, '2_SA', None, {'BTCAUD': False, 'AUDUSDT': False}),
'ETHUSDT':(False, '2_SA', None, {'ETHAUD': False, 'AUDUSDT': False}),
'XRPBTC':(False, '2_SA', None, {'BTCAUD': False, 'XRPAUD': False}),
'XRPETH':(False, '2_SA', None, {'ETHAUD': False, 'XRPAUD': False}),
'BNBUSDT':(False, '2_SA', None, {'BNBAUD': False, 'AUDUSDT': False}),
'ADABTC':(False, '2_SA', None, {'BTCAUD': False, 'ADAAUD': False}),
'ADAETH':(False, '2_SA', None, {'ETHAUD': False, 'ADAAUD': False}),
'ADAUSDT':(False, '2_SA', None, {'AUDUSDT': False, 'ADAAUD': False}),
'ADABNB':(False, '2_SA', None, {'BNBAUD': False, 'ADAAUD': False}),
'XRPUSDT':(False, '2_SA', None, {'XRPAUD': False, 'AUDUSDT': False}),
'XRPBNB':(False, '2_SA', None, {'XRPAUD': False, 'BNBAUD': False}),
'DOGEBTC':(False, '2_SA', None, {'BTCAUD': False, 'DOGEAUD': False}),
'DOGEUSDT':(False, '2_SA', None, {'AUDUSDT': False, 'DOGEAUD': False}),
'BNBBUSD':(False, '2_SA', None, {'AUDBUSD': False, 'BNBAUD': False}),
'BTCBUSD':(False, '2_SA', None, {'BTCAUD': False, 'AUDBUSD': False}),
'BUSDUSDT':(False, '2_SA', None, {'AUDBUSD': False, 'AUDUSDT': False}),
'XRPBUSD':(False, '2_SA', None, {'AUDBUSD': False, 'XRPAUD': False}),
'ETHBUSD':(False, '2_SA', None, {'ETHAUD': False, 'AUDBUSD': False}),
'ADABUSD':(False, '2_SA', None, {'AUDBUSD': False, 'ADAAUD': False}),
'BUSDTRY':(False, '1_SA', 'nic', {'AUDBUSD': False}),
'EURBUSD':(False, '1_SA', 'nic', {'AUDBUSD': False}),
'GBPBUSD':(False, '1_SA', 'nic', {'AUDBUSD': False}),
'DOGEBUSD':(False, '2_SA', None, {'AUDBUSD': False, 'DOGEAUD': False}),
'BTCAUD':(False, 'start', None, {}),
'ETHAUD':(False, 'start', None, {}),
'AUDBUSD':(False, 'start', None, {}),
'XRPAUD':(False, 'start', None, {}),
'BNBAUD':(False, 'start', None, {}),
'AUDUSDT':(False, 'start', None, {}),
'DOGEAUD':(False, 'start', None, {}),
'ADAAUD':(False, 'start', None, {})}
wss_url = 'wss://stream.binance.com:9443/stream?streams=%s' % ['/'.join(key.lower() + '@depth10@1000ms' for key,value in l_ST_symbol_pair.items() if value[1] == 'start')][0]
wss = websocket.WebSocketApp(wss_url,on_message=lambda wss, message: on_message_fiat(wss, message, l_ST_symbol_pair))
wss.run_forever()
