Do you now if i can open an OCO order for futures using binance API?
Thank you in advance for your help!
Hi OCO is not available for futures yet.
Hi Zakaria,
As dino has mentioned, OCO has not been implemented for the Future API.
Just for additional reference in the future, you can refer to the Change log in the API Documentation if it’s ever implemented. Assume that if the endpoint is not in the official documentation, it does not exist.
You can also refer to the Announcements Page for API Updates for any changes as well.
Thanks!
