not receiving events on USER_STREAM subscribeUserDataEvent listener
Hey guys is it normal not to receive any events when I close or add to a position on my account, with the following code ?
RequestOptions options = new RequestOptions();
            SyncRequestClient syncRequestClient = SyncRequestClient.create(PrivateConfig.API_KEY, PrivateConfig.SECRET_KEY,
                    options);
            // Start user data stream
            String listenKey = syncRequestClient.startUserDataStream();
            System.out.println("listenKey: " + listenKey);
            LOG.info("listenKey: " + listenKey);
            // Keep user data stream
            syncRequestClient.keepUserDataStream(listenKey);
client.subscribeUserDataEvent(listenKey, new SubscriptionListener<UserDataUpdateEvent>() {
                @Override
                public void onReceive(UserDataUpdateEvent data) {
                    LOG.info(data.toString());
                    LOG.info(data.getEventType());
                    LOG.info(data.getEventTime());
                    System.out.println(data.toString());
            }, new SubscriptionErrorHandler() {
                @Override
                public void onError(BinanceApiException exception) {
                    LOG.info("ERROR : " + exception.getMessage() + "   " + exception.getErrType());
                    System.out.println("ERROR : " + exception.getMessage() + "   " + exception.getErrType());
Regards,
Andrei
we can’t really help you debug your code. Please try to run/debug by yourself.
If you see any error from server, we may be helpful to give some suggestions.
