NoSuchKey on https://data.binance.vision/data/spot/ for existing data
i tried to download zips from this address but there are lots of missing data.
some have a reason but other do not.(because the klines missing exist elsewhere)
got a list of 1422 errors like this just for monthly klines for symbols status=trading
https://data.binance.vision/data/spot/monthly/klines/ETHBTC/1d/ETHBTC-1d-2024-04.zip”: “<?xml version=\"1.0\" encoding=\"UTF-8\"?>\nNoSuchKeyThe specified key does not exist.data/spot/monthly/klines/ETHBTC/1d/ETHBTC-1d-2024-04.zip9XVX11C86NDFAT92msVzVyvZMAOGWxvc1yGKOiJwgZEjvOZtaRoREQV9fR0qmYuWOPmX/sN5nUIaTXPZgpJebJ1Ucbk=”,
i also tried your binance public data library but it has an error somewhere when i precise a folder in the arguments.
tried on windows
When you mentioned trying the Binance public data library, were you referring to this repository: GitHub - binance/binance-public-data: Details on how to get Binance public data
What happens when you run the following command: curl -s "https://data.binance.vision/data/spot/monthly/klines/ETHBTC/1d/ETHBTC-1d-2024-04.zip" -o ETHBTC-1d-2024-04.zip
Alternatively, you can also try this command in the python folder after installing the necessary dependencies: python3 download-kline.py -t spot -s ETHBTC -i 1d -skip-daily 1 -startDate 2024-04-01
