It seems like the mining api doesn’t include any kind of order number or unique identifier. Is this by design or is there a unique identifier that isn’t being sent?
May I ask which endpoint you are referring to?
Sorry should have included that:
GET /sapi/v1/mining/payment/list (HMAC SHA256)
It’s by design, the profit record does not have a unique ID.
And it never will?
I’m asking because the software I’m developing assigns unique IDs to all transactions and if unique IDs are introduced in the future there will be a mismatch.
Thanks for the prompt response!
And it never will?
Not for the foreseeable future.
