Hi guys,
I’m trying to take the liquidity swap story with this request:
GET /sapi/v1/bswap/liquidityOps
The results obtained are insufficient to be used:
"operationId": 12341,
"poolId": 2,
"poolName": "BUSD/USDT",
"operation": "ADD", // "ADD" or "REMOVE"
"status": 1, // 0: pending, 1: success, 2: failed
"updateTime": 1565769342148,
"shareAmount": "10.1"
As you can see in the image, the data provided by the private API are greater and I refer to the Amount column where it is possible to take the data of the coins inserted in the pools.
Who can help me?
