MAX amount to enter the position
In this picture, how can I detect the max amount to enter the position via python future binance code, if there is no code, how to calculate, it’s needed for the quantity here:
result = request_client.post_order(symbol=“ETHUSDT”, side=OrderSide.BUY, ordertype=OrderType.LIMIT, price=1500, quantity=0.5, timeInForce=TimeInForce.GTC)
thanks
price * quantity should <= your availableBalance from /fapi/v2/account
thanks
We are in USD-M future, so there is leverage, mostly it’s:
USDT / Price * Leverage, but this will not give me the exact “MAX” that I see on trading platform for long position and short position, while MAX differ between long and short as you see in the picture. I hope that there is a code that will give me that directly.
Yeah. Let me correct it. You need to consider open loss. Please read this for a better understanding - https://www.binance.com/en/support/faq/87fa7ee33b574f7084d42bd2ce2e463b
thanks for your help,
look here at these two red squares selected in this picture:
max quantity to open a long position is 0.015 BTC, and max quantity to open a short position is 0.015 BTC. how can I get this via python,
I have tried these python codes,
but I still can’t find that MAX:
Read https://www.binance.com/en/support/faq/87fa7ee33b574f7084d42bd2ce2e463b and calculate it yourself
Thank you very much, I am really thankful.
Hey !
Finally, how you get the long max amount and the short max amount ?
Because, i can’t get it successfully :sleepy:
Thank’s a lot by advance !
I’ve found the solution: Max quantity calculation
