Sairav
1
I am trying to fetch my futures balance , url formed is →
https://fapi.binance.com/fapi/v2/balance?timestamp=1667816992221&signature=my-signature
But I’m getting response →
- “code”: -1102,
- “msg”: “Mandatory parameter ‘timestamp’ was not sent, was empty/null, or malformed.”
I am sending the timestamp value in the url but.
dino
2
please feel free to test the endpoint by this example code.
Sairav
3
using this example code , it gives me →
{'code': -2015, 'msg': 'Invalid API-key, IP, or permissions for action, request ip: 3.70.54.175'}
I am using the same api key I have been using before for margin trading and it has been working.
This is a FAQ and it’s usually solved by checking the possible reasons on:
Sairav
5
My bad , I’ve been preparing the url correctly but during
requests.get(url,headers = headers)
I was giving base_url with no params (timstamp and signature), silly mistake.
Thanks for your inputs…
