Hi there,
I use the following code to get live subscription to tickers using the API.
ProductSubscription subscription = ProductSubscription.create().addTicker(CurrencyPair.ETH_BTC).build();
exchangeStream.connect(subscription).blockingAwait();
exchangeStream.enableLiveSubscription();
Disposable tickers = exchangeStream.getStreamingMarketDataService().getTicker(CurrencyPair.ETH_BTC).subscribe(ticker -> System.out.println(ticker));
However, I see the updates coming exactly once every second, but I need live updates.
Is there a possibility to get the updates of the tickers instantly, and not in intervals of one second?
Thank you for your help.
Hi @Owen_McMushroom, which ticket’s stream name do you refer to?
In our Spot API documentation -> Market Websocket streams section , you can find “Update Speed” for each stream, if only 1000ms
is mentioned then the lowest interval is already 1s.
I honestly don’t know, I use the org.knowm.xchange repository, that implements the class StreamingExchange and I didn’t deal with ticket’s stream names.
The thing is that a few months ago, I am pretty sure that I managed to have real time updates on the tickers, but I dont’t exactly remember how I did that.
Is there a way to get real time updates for tickers?
Hi @Owen_McMushroom, there’s several ticker streams and if you can discover which one you’re using from org.knowm.xchange
, then you can find the update speed in the API documentation.
As you can expect, we can’t change the update speed besides what’s already mentioned there.
Thank you, I figured out, that by default org.knowm.xchange subscribes to the tickers, but one has to use bookTickers instead.
