I am facing problem only with using (GET “/sapi/v1/staking/personalLeftQuota”) i give the parameters for product and productId.
parameters = {
"product": "STAKING",
"productId": "Axs*90"
and i am getting the following error {“code”:-1022,“msg”:“Signature for this request is not valid.”}’
Note: when changing the productId to BTC001 i get the following error
{“code”:-9000,“msg”:“Project not exist with projectId BTC001”}
I am pretty sure that the signature is implemented correct. i have no issue when using any other API even the api for staking only this api has issue
