Isolated Margin API trailingDelta not supported?
the web interface for Isolated Margin supports Trailing Stop orders, but the Margin API does not?
The trailingDelta parameter gets completely ignored on Isolated Margin API. (i.e. no “d:” field in the order stream executionReport, and the order executes immediately.)
It is also not listed at: Binance API Documentation
Are there any plans to support trailingDelta in the Margin API?
Thanks!
Thanks for the feedback, It’s in the plan but no ETA yet.
Hi, any ETA now?
+1 on this, it would be super useful and it’s already implemented in the engine because it’s open on the web, so it should be easy to open it for the API
Hello, is there any news ? It will be very useful , +1, not possible to use same spot code :slight_smile:
