Hi guys is possible, have only a quote symbol ? example if you have BTCUSDT i want call some API and return only USDT because i want know a list of all quote thanks
No, that’s not support from endpoint, however you can fetch all of them and filter in the client side. Should be an easy one.
thanks i find a solution in exchange info return base anquote asset separatly thanks again
