"Invalid symbol status for opening position"
“binanceusdm {“code”:-4140,“msg”:“Invalid symbol status for opening position.”}”
Any idea about this problem.
my order is like this:
{“symbol”:“BTSUSDT”,“side”:“SELL”,“type”:“MARKET”,“timeInForce”:“GTC”,“quantity”:1199,“timestamp”:1671619596174}
which endpoint did you call? what’s the parameters sent in the request?
endpoint is POST /fapi/v1/order
parameters are shown above as json format
Hello, there is no “BTSUSDT” pair on Binance Futures USD-M. Maybe you want to use the Spot API? Please check the API endpoint.
Spot API Endpoint:
https://api.binance.com
BTSUSDT Pair:
https://www.binance.com/en/trade/BTS_USDT
