IMPORTANT BUG at POST /sapi/v3/asset/getUserAsset error
in POST /sapi/v3/asset/getUserAsset
there is an error of response of btcValuation param.
all values of btcValuation is 0 now.
please fix this problem asap :slight_smile:
It looks like the issue doesn’t occur when you set the parameter needBtcValuation to true: Binance API Documentation
If the problem persists, I invite you to contact the customer support for further assistance.
Thanks albin. I’m using that function since 3months ago in my system. But ,suddenly it changed even I was not changed my code. So… something changed at API.
