Struggling to grab more than 1000 candles from Binance’s API without missing a beat? You’re not alone. Here’s a swift rundown:
The provided code does a decent job fetching candlestick data from Binance, but it consistently misses the last three candles. Why? The culprit lies in how it calculates the start time for each iteration. By simply adding one second to the timestamp of the last fetched candle, it overlooks potential gaps between candles.
To remedy this, adjust the code to set the start time for the next iteration just after the timestamp of the last candle fetched.
s_time = int(new_klines[-1][0]) + 1
Here’s the full code for your reference:
def _get_kline(self, cc, interval, limit, start_time='none', end_time='none'):
""" Get historical kline by {interval}, {limit}, {time_end}, and {time_start} => Returns a json. """
params = {
'symbol': cc,
'interval': intervals[interval],
'limit': limit
if start_time != 'none':
params['startTime'] = start_time
if end_time != 'none':
params['endTime'] = end_time
return self._get(binance_endpoints['klines'], params)
def get_historical_kline(self, cc: str, interval: str, dataframe_limit: int, start_time=None, end_time=None, get_ts=False):
klines = []
curr_time = round_down_timestamp(get_curr_ts(), 15)
s_time = reduce_from_timestamp(curr_time, 15, dataframe_limit)
while True:
# Fetch Klines
new_klines = self._get_kline(cc, interval, 1000, s_time)
# Append fetched Klines to the existing list
klines += new_klines
# If less than 1000 Klines were retrieved, we have reached the end of available data
if len(new_klines) < 1000:
break
# Update start time for the next iteration
return klines_to_dataframe(klines, get_ts)
