for example, I send 2 orders on binance swap: buy btcusdt 1.0 and sell ethusdt 2.0 and both are by ‘limit’ orders; I want to get the info by api for any trading on them, such as btcusdt 0.5, eth 0.2; how shall I write the code, shall I get an demo?
I know I should use this link ‘Binance API 使用文档’, but I don’t know the exact details.
There is no websocket stream for Swap order changes. You can get relevant order data from the Swap History endpoint.
https://binance-docs.github.io/apidocs/spot/en/#get-swap-history-user_data
Hi tantialex
thanks for your reply;
I am not familar with this development, and I guess I should use the url like this ‘Buy/Sell Bitcoin, Ether and Altcoins | Cryptocurrency Exchange | Binance(HMAC SHA256)’;
then my question is that:
- how to generate my HMAC SHA256, could you show a demo?
- requests.get(this url) to get swap holding?
- how many time I can get this data after I post a new order?
You can find samples of generating the signature in different languages here.
You can find a sample example of Get Swap History in our official connectors.
Python Example
Other connectors
It’s available right after the order is sent. However it will remain pending until it is matched. This time frame is unknown.
