How to use Websocket / Python
I want to query some markPrice symbols using Websocket, and I´d like to know if there is information about it using Python.
Regards,
Orlando Gautier
Hello, I do not underestand your answer. Could you explain to me please.
Thank you!
sorry i posted something wrong , so i deleted it,
I request can you help me with my question?
Thank You
sure, please post the question in a new topic. thank you
If I got it right, it’s about how to listen to websocket stream in python?
I´m connecting using:
client = Client('xxxx', 'xxxx')
from binance.websockets import BinanceSocketManager
bm = BinanceSocketManager(client)
def process_m_message(msg):
print("stream: {} data: {}".format(msg['stream'], msg['data']))
conn_key = bm.start_multiplex_socket(['sxpusdt@aggTrade', 'sxpusdt@ticker','sxpusdt@markPrice'], process_m_message)
bm.start()
It works fine…
But when I try to get sxpusdt@markPrice or sxpusdt@markPrice@1s it does not work. I don´t know if it is neccesary to subuscribe to this work.
Regards,
Orlando Gautier
markPrice is only from futures, it will return data if this bm can also handle futures streams.
youre supposed to put in AsyncClient not Client
Here is an example file with an other lib: https://github.com/oliver-zehentleitner/unicorn-binance-websocket-api/blob/master/example_binance_futures_1s.py
Thank you Dino,
