async def send_ping(stream: ReconnectingWebsocket):
#TODO: check for pong message
while True:
await stream.ping()
print(f"Ping sent at time: {datetime.datetime.now(utc_2)}")
logging.info("Ping sent")
except Exception as e:
logging.info(f"Failed to send ping: {str(e)}")
break
await asyncio.sleep(60*10) # Ping every 10 minutes
async def async_stream_data(symbol, bsm: BinanceSocketManager, connection_status):
global stream_weights
max_backoff_interval = 3600
backoff_interval = 60
reconnect_interval = 60*60
rl = RateLimiter(6000, 1)
ping_tasks = []
#run an infinite loop so it reconnects when the connection is lost or an error occurs
while True:
async with bsm.futures_multiplex_socket(streams=[f"{symbol.lower()}@depth20@100ms", f"{symbol.lower()}@kline_4h", f"{symbol.lower()}@trade"]) as stream:
logging.info(f"Connected to {symbol}")
connection_status[symbol] = True
#Ping task
loop = asyncio.get_event_loop()
ping_task = loop.create_task(send_ping(stream))
ping_tasks.append(ping_task)
async def main():
global bot_start_time
bot_start_time = datetime.datetime.now(utc_2)
hello_message_txt = f"""
š° ----- LOB-bot š -----
- Started at : {bot_start_time}
- Coins : {async_coins}
{notes}
await send_telegram_message(hello_message_txt)
global order_books, columns, BUFFER_SIZE
#client = Client(api_key, api_secret)
client = await AsyncClient.create(api_key, api_secret)
bsm = BinanceSocketManager(client,user_timeout=60)
ws_coins = ["BTCUSDT", "WIFUSDT"]
tasks = []
connection_status = {coin: False for coin in ws_coins}
for coin in ws_coins:
tasks.append(loop.create_task(async_stream_data(coin, bsm, connection_status)))
# await all asyns tasks
return await asyncio.gather(*tasks, return_exceptions=True)
print(f"An Exception occured in main: {e}")
if __name__ == "__main__":
asyncio.run(main(), debug=True)
Iāve spent hours and I canāt find any documentation on how to send/receive ping and pong and their responses format that supports asyncio and futures. Iāve left a snippet of relevant code above.
I have read the binance future connector github repo binance-futures-connector-python/binance/websocket/binance_socket_manager.py at main Ā· binance/binance-futures-connector-python Ā· GitHub
If i use the BinanceSocketManager from here i get this error, itās apparently not suitable with AsyncClient:
TypeError: argument of type āAsyncClientā is not iterable
Anyone please help. My code stops running on the server due to this. As of now Iām fetching my BinanceSocketManager(BSM) using this this path from python-binance package
from binance.streams import BinanceSocketManager
it results in Error: āstreamā using this BSM version, Iām certain it comes from syntax error in send_ping:
await stream.ping()
Any help is deeply appreciated
