my question is how do you work around the streaming subscription limitation and when do they take effect? The documentation says to avoid listening to more than 200 streams.
Considering the limit of 200 streams per connection and the restriction of sending no more than 10 messages per second, it’s advisable to send requests from different IPs.
Exceeding the limits of message, as outlined in the documentation, may result in your IP being banned, preventing further requests from that IP.
hey, thanks for the explanation for the 10msg per second, but how do you go about receiving messages? As in price updates? Can you subscribe to more than 200 streams (say bookTicker) from one IP?
You should open multiple connections, with each listening to a subset of streams.
Using the same IP address is fine. There is no limit on the number of listening connections, so you long as you can keep up with the update rate.
Note that this is the limit on the incoming messages (from you to the server): e.g., channel subscription requests. This does not limit the rate at which updates are streamed to you.
