How to know on which layer-1 (BTC, ETH) is built a cryptocurrency ?
Thanks by advance.
Luzrod.
Thanks by advance.
Luzrod.
https://binance-docs.github.io/apidocs/spot/en/#all-coins-39-information-user_data
If you meant the base network, you can find it using this endpoint.
Thanks ! But is it possible to have this information without authentification ?
