I am currently testing out spot API. I placed an order that trades 10USDT for 0.0002BTC, and I can see that my order is executed from my order history tab like below.
And when I request trade history through Postman, it returns the multiple transactions in JSON like this:
"a": 901227218,
"p": "48832.30000000",
"q": "0.01367000",
"f": 1029684907,
"l": 1029684907,
"T": 1630267406847,
"m": true,
"M": true
"a": 901227219,
"p": "48832.26000000",
"q": "0.00330000",
"f": 1029684908,
"l": 1029684908,
"T": 1630267406847,
"m": true,
"M": true
"a": 901227220,
"p": "48832.02000000",
"q": "0.00040000",
"f": 1029684909,
"l": 1029684909,
"T": 1630267406847,
"m": true,
"M": true
After quick googling, I noticed that market orders can be filled with a series of transactions until the total sum of quantity meets the requested amount. However, I have a completely different number which is 20.4494 when I add up quantity (“q”) value from all transactions.
Isn’t it supposed to be the amount of BTC, I bought with 10 USDT?
Also, if I just want to get data that matches exactly the same as the one from the order history tab, which endpoint should I use?
