Use GET /api/v3/myTrades
to list trades you’ve done to fill the order, then sum them.
This endpoint returns the details of your trades with counterparties as well as the commissions that you pay the exchange.
For example, here’s an order to MARKET BUY some BTC for USDT with quoteOrderQty=5000.00
GET /api/v3/order?symbol=BTCUSDT&orderId=6505618
returns a summary of the order, confirming that it’s fully FILLED:
Response
"symbol": "BTCUSDT",
"orderId": 6505618,
"orderListId": -1,
"clientOrderId": "DbEbedtckod2SvnEDSupeG",
"price": "0.00000000",
"origQty": "0.08403000",
"executedQty": "0.08403000",
"cummulativeQuoteQty": "4999.91598920",
"status": "FILLED",
"timeInForce": "GTC",
"type": "MARKET",
"side": "BUY",
"stopPrice": "0.00000000",
"icebergQty": "0.00000000",
"time": 1726438360369,
"updateTime": 1726438360369,
"isWorking": true,
"workingTime": 1726438360369,
"origQuoteOrderQty": "5000.00000000",
"selfTradePreventionMode": "EXPIRE_MAKER"
from which you can see that I’ve paid 4999.91598920 USDT in total (cummulativeQuoteQty
) and received 0.08403000 BTC in total (executedQty
). However, this doesn’t include the information on commissions, so the actual quantity that I’ve received might be different.
GET /api/v3/myTrades?symbol=BTCUSDT&orderId=6505618
returns more detailed information about the individual trades:
Response
"id": 1594825,
"orderId": 6505618,
"orderListId": -1,
"price": "59500.01000000",
"qty": "0.00340000",
"quoteQty": "202.30003400",
"commission": "0.00000000",
"commissionAsset": "BTC",
"isBuyer": true,
"isMaker": false,
"isBestMatch": true
"id": 1594826,
"orderId": 6505618,
"orderListId": -1,
"price": "59500.12000000",
"qty": "0.00757000",
"quoteQty": "450.41590840",
"isBuyer": true,
"isMaker": false,
"isBestMatch": true
"id": 1594827,
"orderId": 6505618,
"orderListId": -1,
"price": "59501.78000000",
"qty": "0.07306000",
"quoteQty": "4347.20004680",
"isBuyer": true,
"isMaker": false,
"isBestMatch": true
Here you can see that I’ve made three trades:
Trade "id" |
"price" |
"qty" |
"quoteQty" |
"commission" |
1594825 |
59500.01000000 USDT |
0.00340000 BTC |
202.30003400 USDT |
0.00000000 BTC |
1594826 |
59500.12000000 USDT |
0.00757000 BTC |
450.41590840 USDT |
0.00000000 BTC |
1594827 |
59501.78000000 USDT |
0.07306000 BTC |
4347.20004680 USDT |
0.00000000 BTC |
Tallying up qty
, we get 0.08403000 BTC (same as executedQty
). Similarly for quoteQty
(which is price
× qty
), ending up with cummulativeQuoteQty
If testnet had any commissions (lol) then the commission
value would be non-zero
You sum them up like other quantities and get a total that you’ve paid for the order.
- Commissions are not included in
qty
and are deducted separately.
- Commissions can be paid in BNB if you choose to use the discount. In this case they are deducated from your free BNB balance, if it is sufficient.
- Otherwise, commissions are deducted from the asset you receive:
- e.g., if you buy BTC for USDT then commissions are deducted from the BTC you receive from the trade (you actually get less than
executedQty
- similarly, if you sell BTC for USDT and don’t pay in BNB, then commissions are deducted from USDT that you get (which you get less than
cummulativeQuoteQty
- Commissions are computed and deducted for each trade individually.
