how to get signed
I used a string from the interface document as an argument and the result is inconsistent with the example,does it can’t just concatenate parameters with &
This depends on the language and method used to generate the signature. I suggest having a look at this repository for more examples on how to generate the signature.
I solved this problem ,I used to use base64 so I got wrong answer, thank you
