My kind of order is C2C.
According to the sapi documentation, response of CommonRet_OrderMatchResp_ (getUserOrderDetail ) include registerDays and completedOrderNum, but i can find it in response.
Or you can return me 1 field BuyerUserNo/SellerUserNo.
Thank you very much!
Hello, where is this “sapi documentation” that you refer to?
I’m afraid it might be a question out of our control at this forum, we only look into APIs present at https://binance-docs.github.io.
@aisling2 I use this api /sapi/v1/c2c/orderMatch/getUserOrderDetail.
Please help me check this!
Apologies, although /sapi/v1/c2c/orderMatch/getUserOrderDetail
is not available at https://binance-docs.github.io/apidocs/spot/en/#get-c2c-trade-history-user_data
, so we don’t have knowledge about it.
Try to see if you can find a support contact from where you got that endpoint please.
