How do i use the api/v3/allOrders ?
I created the hmac signature and made a request with the signature in the params i get this
data: {
code: -1104,
msg: "Not all sent parameters were read; read '2' parameter(s) but was sent '3'."
data: {
code: -1104,
there is one parameter not required sent to sever, pls share the original parameters for debug. No signature.
var query = {
symbol,
timestamp: from,
query = qs.stringify(query);
const sign = crypto
.createHmac("sha256", api_secret)
.update(query)
.digest("hex");
const response = await axios({
url: "/api/v3/allOrders",
method: "GET",
baseURL: "https://api.binance.com",
headers: {
"X-MBX-APIKEY":
"VTRydFVYKEOlzXCmvg1LLZKkGcx6IaO5egtPG24ro170XXXXXXXXXXXX",
params: {
symbol,
timestamp: from,
singature: sign,
}).catch((err) => {
console.error(err);
here us the snippet im using. Thanks in advance !
This code is receiving the SYMBOL and FROM param from a function call
have a try by adding all parameters in the url, like
GET https://api.binance.com/api/v3/allOrders?symbol=BTCUSDT×tamp=1592303537329&signature=4e48387a5a0f708b67776d8cbaea55
I’m getting this new error for whatever timestamp iinput. Even the current timestamp
"code": -1021,
"msg": "Timestamp for this request is outside of the recvWindow."
your local time is out of sync, please try to sync to standard time.
set recvWindow = 60000 may reduce the chance of this error, but not recommend for production.
Standard time as in UTC?
I managed to figure out the timestamp but i’m still stuck with the original issue
/api/v3/allOrders?symbol=BTCUSDT×tamp=1592388274003000&recvWindow=60000&singature=66e09f9bd353f736ffbeeb9b246ba55ef69b78e6e06e5c19358xxxxxxxxxx
This gives me
data: {
code: -1104,
msg: "Not all sent parameters were read; read '3' parameter(s) but was sent '4'."
timestamp is 13 number, in milliseconds
singature???
what parameter is that?
