How to get btc rate against usd using binance api ?
Hi, I have checked the api docs throughly but I dont know where is the endpoint to get the rate of e.g btc to usd or eth to usd ? Everywhere there is btc to USDT and not USD … Please guide me
Hi, there is no symbol trading in USD on binance.com, so you can’t get the coin rate in USD. You may get the rate of USDT to USD from third party, which can be helpful for you.
I got the solution, this is the required endpoint to get btc/etc or any othey coin rate to USD.
{{url}}/sapi/v1/portfolio/asset-index-price?asset=BTC
it gives response like this
“asset”: “BTC”,
“assetIndexPrice”: “42584.3643268”,
“time”: 1705505244045
Try the following code
import requests
apis = {
    "BINANCE": {
        "base": "https://api.binance.com",
        "endpoint": "/api/v3/avgPrice"
    "BITSTAMP": {
        "base": "https://www.bitstamp.net",
        "endpoint": "/api/v2/ticker/"
def get_binance_price(symbol):
    base = apis['BINANCE']['base']
    endpoint = apis['BINANCE']['endpoint']
    price = 0.0
    payload = {
        "symbol": symbol
    url = f"{base}{endpoint}"
    r = requests.get(url, payload)
    if r.status_code == 200:
        d = r.json()
        if "price" in d:
            price = float(d['price'])
        else:
            print(d)
    return price
def get_bitstamp_price(symbol):
    s = f"{symbol[:-4]}{symbol[-4:]}"
    base = apis['BITSTAMP']['base']
    endpoint = apis['BITSTAMP']['endpoint']
    price = 0.0
    r = requests.get(url)
        d = r.json()
        for item in d:
            pair = item['pair']
            if pair == s:
                price = float(item['last'])
    return price
def price_of(symbol):
    usdt = get_binance_price(symbol)
    if usdt > 0.0:
        usd = get_bitstamp_price(f"USDT/USD")
        if usd > 0.0:
            return usdt, usd
if __name__ == "__main__":
    symbol = "BTCUSDT"
    btc_usdt, usd_usdt = price_of(symbol)
    print(f"BTCUSDT : {btc_usdt:,.3f}")
    print(f"USDTUSD : {usd_usdt:,.4f}")
    print(f"BTCUSD  : {btc_usdt * usd_usdt:,.3f}")
