Hello there,
I’m building an app and I need to get ALL spot trades, I’m using this endpoint /api/v3/myTrades?symbol=BTCBUSD&fromId=0&limit=500×tamp=1635612580349&signature=...
but it’s returning only 21 trades (I think this response represents the last 3 months)
I started trading in March (this year) and I’m sure I have done more than 21 trades and way less than 500 trades, so my question is why I’m getting only a portion? what should I do to get everything???
thanks in advance for you help!
The myTrades endpoint does not limit from how far back a user can retrieve their trades.
You can confirm this by matching the results with the trades from Binance UI.
Hi @tantialex, if this is the case, something else is going on, because I get a longer result from Binance UI
am I doing something wrong or is this a bug???
Could you provide the URL of the Binance UI and a sample of the parameters sent to the /myTrades endpoint?
this is for the endpoint
for the Binance UI I go to
https://www.binance.com/en/my/orders/exchange/usertrade
and then click on Export Trade History
I could not reproduce the issue, I was able to obtain trades which happened at the beginning of the year (January).
Could you provide a sample of a trade from the export (omit any sensitive data) which you are not able to retrieve from the API?
