I wrote the code to get exchangeInfo response in SBE format. How can I decode the response?
Here is a list of repositories in various languages that include examples demonstrating how to make requests and decode responses in SBE format:
Thanks, but I can’t find no examples in javascript language.
Yes, the provided examples do not include scripting languages.
If you wish to test using the examples, you’ll need to use either Java, C++, or Rust.
