I have asked this question before but have not received any answer, searching the internet, Binance etc. have not really given an clear answer and ChatGPT say something like this:
“If you’re building a trading bot, checking the exchangeInfo data at least once per hour should suffice unless Binance releases critical updates requiring immediate action.”
Is there any official information on this subject ?
Hi @rabol, the exchangeInfo data on Binance is updated whenever there are changes to the exchange’s trading rules, symbols, or trading pairs. These updates are not on a fixed schedule but typically occur in the following scenarios:
New Symbol Listings: When Binance adds new trading pairs or assets.
Symbol Delistings: If a trading pair is removed.
Trading Rule Updates: Changes to filters, precision, or limits (e.g., minimum order size, maximum price).
To stay informed you can always do the following:
Monitor Binance announcements for updates related to trading pairs or rules.
For most use cases, checking exchangeInfo once per day is generally sufficient unless you anticipate frequent changes or rely on up-to-the-minute accuracy.
If your application requires real-time precision and filters, you might consider fetching exchangeInfo more frequently (e.g., once per hour) or whenever you notice unusual behaviour/errors (like a rejected order due to filter mismatches).
