https://api.binance.com/api/v3/exchangeInfo?symbol=${symbol}
In order to get the Filters for a coin pair, I hit this endpoint, for every coin pair I need to operate on, which is expensive in terms of time.
Can I just fetch info for all pairs and persist, then operate based on the persisted info (i.e how often does the data change and how often do I need to fetch this info ?)
