Q: So I wish to know what happened after I sent a RESTful request to API server?
A: There are many validations applied in the API server backend, all of them can be found from our API document. Here is a summary of them.
We will take the endpoint of place order for example: POST /api/v3/order
[Click the image to zoom out]
Details in some step:
params are all allowed?
- this check will fails if you don’t provide parameter not in the document.
other parameter check
- this check is depending on the requirement of each endpoint, in this endpoint, e.g.
icebergQty
>quantity
, check the API document for details.
filter check?
- this validation is unique in placing order and very import, each filter is defined from endpoint
GET /api/v3/exchangeInfo
- common filters are PRICE_FILTER, LOT_SIZE, MIN_NOTIONAL, etc
