I didn’t see any info about timelimit or times limit in Documentations.
I sent PUT /fapi/v1/listenKey
every 30min but in one moment got EVENT listenKeyExpired
on channel?
Why is it?
on channel?
Why is it?
if you delete the listenKey via DELETE /fapi/v1/listenKey
, the EVENT listenKeyExpired
will be received in the client too.
I didn’t DELETE and periodical prolongate by PUT only
Is it happening intermittently or you are not able to renew the listenKey, they are different directions for investigation. Thank you
How can I check that listenKey is updated successfully by response? I don’t see anything in API answer of PUT /fapi/v1/listenKey
The response returns 200 as soon as renew is accomplished.
