In Binance javascript sdk there is a function crypto.getPrivateKeyFromKeyStore(keystore, password)
that allows you to read private key from the binance keystore. How to do the same in Java? I couldn’t find similar method in java sdk. Any tips?
Hi.
Please ask the question on Binance chain forum instead. Here is for the API usage.
Thank you!
